メインコンテンツにスキップ
New light only turns on when I tap the bulb -RESOLVED
I installed a new 4 foot, 2 lamp fixture. I installed new bulbs with the power on and they lit up. Great, I thought and turned it (and the other fixures) off with the switch. Problem is, the new fixture won't turn ON with the switch. The others do. If I lightly tap the new bulbs it'll light up. What am I doing wrong.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@augustine01 try to reset the bulbs first
さんによる
Thank you. I've tried that several times but doesn't seem to help.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@augustine01
Hi,
Do you only have to tap one tube for both the lights to turn on and if so is it either tube or always the same one?
In any event since it is new, return for a refund or replacement as opening the fitting will void the warranty.
Pain I know but it may prevent frustrations or problems in the future if you have a fitting that worked properly from the get go.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's just one tube. But yes, you're right. I'm giving up on it. Thanks for the help!
さんによる
コメントを追加
回答を追加する
Brian Crane さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 894
