メインコンテンツにスキップ
Model numbers JSN-L21 and JSN-L42.
35回答 すべてを表示
Phone not responding, no charge indicator light.
My smartphone stopped working after i had charged it to 100% capacity overnight. The next morning i was still able to use the phone, but i noticed it stopped working after class. The battery is still fine (i checked it with a multimeter). Maybe a broken powerswich? There is no red indicator light or a charging iconon the screen (Was just replaced) while trying to charge the smartphone. Maybe a bad charging circuit?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
Paul Streck  sure could be a failed charging circuit. The very first thing that you do want to rule out is the battery. You cannot check a battery with a multimeter since it may show proper voltage but can fail under load. Replace the battery and re-evaluate.
Of course, you also want to make sure that your charger works properly as well as your charging cable.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I am 90% shure that the battery is not the problem, because the red charging indicator light is not lighting up. The light shouldn't be that much of a load to cause battery voltage sag. My charger and cable are working properly. I personaly think that there is a problem with the mainboard power delivery since basic things like the charging indicator are not lighting up.
さんによる
コメントを追加
If you know how to open the phone, try unplugging the battery and pressing the power button for 1 minute to drain any excess power in the device that may be causing this.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Tried, but didn't fix it :(
さんによる
コメントを追加
I have slept at night by keeping phone beside me and when I saw morning it didn't work from last 1 month
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Paul Streck さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 37
今までの合計 1,692
