メインコンテンツにスキップ
Blue, red or white 11" Dell Inspiron 11-3162 released on February 16, 2016.
13回答 すべてを表示
disconnected internal wifi wire antenna
hi I’m owning a government property laptop and now because of the problem of my laptop hinge it also damaged my laptop antenna wire
lately, I fixed my hinge and now my only problem is the wire can anyone help me how to fix m WLAN wire?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Here’s a link to the service manual for the laptop, taken from this webpage.
Scroll to p.73 onwards to view the necessary pre-requisite steps and then the procedures for removing / replacing the display panel.
Coupled with this is the WLAN antenna cable removal / replacement etc
If the antenna cable has been damaged you will most probably have to replace it as trying to repair the cable (it is a two wire cable, the signal wire and a shield wire) could lead to losses in the signal strength which could cause WiFi performance problems, e.g. dropouts and also reduced operating distance from an access point.
Replacement antennas are available online. Here’s a link to just one supplier. It is only shown to give you an idea of the cost of the part. There are other suppliers that may suit you better. Just search for Dell Inspiron 11 3162 WLAN antenna cable to get results.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
amielsamson14 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 357
