メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Hover-1社が2018年に製造した電動スクーター。
I have an error code E2 and the scooter move
The scooter was working then all of a sudden an E 2 error came across the screen
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 12
2 件のコメント
Did you ever find out what caused E2 error code? Seems to be a non-existent answer or solution at this point.
さんによる 共有
ChatGPT said:
The E2 error code typically indicates a throttle or communication issue between the controller and throttle on many electric scooters. Since the scooter was working before the error appeared, it's possible that a loose connection or damaged wire is the cause. I recommend checking the throttle cable for any visible damage or disconnection. If everything appears secure, a reset or diagnostic check by a technician may be necessary.
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
Throttle fault. Internal breakage or hall sensor failure. New throttle required unless repair is possible.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Hi Nigel,
It would be helpful if perhaps you could post where you got the information from.
さんによる 共有
Experience to be honest Mike, I repair the odd scooter at work.
さんによる 共有
コメントを追加
I had this issue, ended up ordering another throttle, the hall sensor inside the throttle has 3 wires on it. If you have the throttle off you can press it on the exposed magnets, one side of the sensor on one magnet or the other will cause the error to go away, put the scooter on taxi start and scoot away. This will be trial and error because the center leg on my sensor snapped off, that wire shorted against the outer leg (was green on my scooter) should give you the same results. The other will reboot the scooter. My scooter is the AovoPro es80, depending on your scooter’s settings and where you place the sensor on the magnets you may get a faster or slower speed, mines on slow so I’m at about 10mph but that just saves more battery. Am going to try a variable resistor and a momentary switch as well. Also the AovoPro es80 cuts power to the motor when braking this is helpful because you won’t have to jump off the scooter and lift the front wheel off the ground every time you want to stop.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Alisha さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 161
今までの合計 9,694
