メインコンテンツにスキップ
Standard and high definition handheld video cameras by Sony.
121回答 すべてを表示
I started to get E:62:11 after falling.
After falling on a hard ground from 50cm of height, I started to get E:62:11 after falling. When it occurs, the lens stops balancing and goes aside. Seems to happen when I do stronger movements. Wont buy these balancing lens again. The zoom and focus wheel has been damaged also and its hard to move.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@Karen soghomonyan E:62:11 is an issue with the image stabilization. If the camcorder shows this error you can only try to resetting the camcorder and try again. This is done by removing the battery or ac power, wait 10 second, reapply the battery or ac power and try again.
The other issues appear from more mechanical failure so you will have to try to disassemble it. We will need to know the exact model to see if we can help you with that.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Karen soghomonyan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 638
