メインコンテンツにスキップ
Repair guides and support for televisions manufactured by Sony.
753回答 すべてを表示
KDL-52W5100 - no backlight, no sound
Hello, my Sony KDL-52W5100 all of a sudden has no backlight and no sound. Things I have noticed and done:
  •  Full power down and disconnect from receptacle. Held power button for 30 seconds to fully drain capacitors. Reconnect to power and I immediately hear a single click from the relay. TV goes into standby. Power attempt reveals solid green LED and Sony letters light up, but no backlight or sound.
  • Connected my PC to the HDMI port and turned on. No backlight or sound however the computer properly detects the external display and labels it as a Sony Bravia LCD.
  • Connected my music player (iPhone) to the audio port and cycled inputs (no indication visually that it is actually cycling through inputs - no audio heard.
  • Played an audio clip on the PC while connected to the HDMI port and cycled through inputs, no audio can be heard.
  • Tried to put the TV into service diagnostic mode: Display - Channel 5 - Volume down - Power from the remote while in standby. LED and Sony logo light up, but no diagnostic on screen and again, no backlight, no sound.
  • Opened the back…no visual problems that I can see such as blown/bulging capacitors. No odd smell.
  • Over the years, I have noticed periodically throughout the day, the TV relay would make an audible “click” when the TV was otherwise in standby mode. I never noticed any lights or indication it was power cycling otherwise.
Given the last bullet, I’m thinking power board related? I need to pull the schematic to see if I can detect power to the inverter. Not sure where to take this otherwise?
I know this is a 10 year old TV. It really was only ever used by the kids on weekends to play Xbox and while a new 65” is relatively inexpensive, I would like to give this one a solid shot at repair before committing it to e-waste.
Any feedback would be VERY welcomed!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi,
Did you try to go into Service Adjustment mode?
According to the service manual (hopefully this is for your model i.e. correct chassis number) it is Display - CH 5 - Vol. Up - Power.
The service manual has the schematics and the parts list which should be a help.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Thanks for the reply. Yes, that was my 5th step above however the manual stated Vol.Down instead of Vol.Up, like you mentioned. Either way however, it unfortunately left me with the same symptoms.
さんによる
@Mr DP ,
You said that the Sony logo appears on the screen at startup is this correct?
If the logo does appear then most of the hardware for getting an image to appear on the screen is OK, at least from the mainboard to the screen and the power board as well . Getting it through the mainboard to the screen seems to be the problem
Just wondering if a manual firmware update or reinstall might be worth a try.
I realize that you cannot verify what firmware version is installed and I don't know if Sony allows for older or same firmware versions to be installed over an existing newer version if that is the case.
If you decide to try this then please verify that the firmware that I have linked is for your exact model TV as installing the wrong firmware can "brick" the TV. Click on the "Applicable models" link on the page and check.
Perhaps you should do your own search for "Sony (insert full model number of TV) firmware" and see if you end up with the same firmware version (version aa0211pn)
さんによる
Sorry, no. The Sony logo is below the screen and lights up. The screen remains black unfortunately. I am going to purchase the service manual and see if I can do some voltage tracing. Thanks for the reply.
さんによる
@Mr DP no need to purchase it. Click on the blue link "service manual"provided by @jayeff
Since you have no backlight and no audio your focus should be on the main board
さんによる
I have a 52w5100 with almost the same symptoms. The difference is that my backlight comes on for 30 seconds and then shuts off. The manual at data2.manualslib.com doesn't include the main schematics. The last page says you have to e-mail SONY for them. I have my doubts as to whether that option will bear fruit but I'll give it a try and let everyone know if it works.
さんによる
コメントを追加
hello @mrdp,
sounds like youre pretty capable of troubleshooting. just following up on some your post of testing for voltages. if you were to pull the back to test voltage to the inverter, you may want to go ahead and check the voltages that are printed on the power supply board at the connector going to the main logic board and the voltages printed on the power supply either going to your driver board, or if built in, at the connector leading toward your led’s.
if these are not present, or are very low or jumping up and down, then it may be the power supply. if the voltages are there and steady from the power supply to the main board, it may be the main board that has failed.
this is just a generic response as i dont know what board models are in your particular tv, but this should get you looking in the right direction.
if you are uncomfortable working with live voltage, dont. Do this at your own risk.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mr DP さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 601
