メインコンテンツにスキップ
PS3に同梱されているコントローラーの修理とサポート。 2008年半ばに発売された6軸リチウム電池式コントローラー(CECHZC2)は、修理が簡単です。
157回答 すべてを表示
Why is my controller so glitchy?
So, Ive had this controller for 5 years now and it worked perfectly until last year. It just completely quit. Few weeks later i decided to try it and it didn’t connect wirelessly. So we got a cord and plugged it in.. Holy glitches. it wanted to move up and down, all the way to the right, it started pressing buttons.. so we put that controller up for about 5 months. I tried it again just a few weeks ago and it worked like a dream while it was plugged in. But just yesterday none of the buttons were working, then it did its glitchy thing again. Can this controller be fixed easily? I don’t have much money to buy a new controller and this is my only one.. HELP!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@megladon420 there will be no easy fix since there are no schematics etc. I suggest you start by taking it apart and check the circuit board for any obvious damage like corrosion etc. After that you would need replace the battery and then re-evaluate. The new battery will function as a known-well starting point for more troubleshooting. Post some good pictures of your boards etc. with your Question so we can see what you see. iFixitでの質問に画像を追加する方法 DualShock 3
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Megan Ormsbee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 57
