メインコンテンツにスキップ
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
140回答 すべてを表示
Mtd pro lawnmower wont move
I replaced the drive belt on my mtd pro. Lawn tractor 13at605h718… When i first started the mower and put it in gear it drove about 15 feet… Now it just sits there when i press the gas like the belt has come off but everything is still in tact
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Do the driven wheels work when you manually turn the transmission input pulley with the belt removed?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
No...I realized it wouldn't move because the gas pedal wouldn't come back to normal position... Someone said replace the belt...
さんによる
There are actually two belts required to make that variable speed pulley type drive actually work. https://www.partstree.com/models/13at605...
Further if either is badly damaged or missing the drive won't work properly I expect. Earlier I thought it was a walk behind mower because I failed to read your question correctly. I recategorized your question to reflect that it is a rider type mower.
さんによる
コメントを追加
回答を追加する
Joshua Beck さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 292
