メインコンテンツにスキップ
SCREEN SIZE 46" (117cm), 16:9 TV SYSTEM Digital: DVB-TAnalog: B/G, D/K, I,L,M Year: 2012-2013 http://www.sony.com.sg/electronics/support/televisions-projectors-lcd-tvs/kdl-46hx855/specifications
20回答 すべてを表示
What does it mean when my TV has colored stripes up and down screen?
I was watching it went out of the room for a few minutes came back and my TV shuts off if it hasn't been messed with in 4 hours so when I noticed that it shut off I turned it back on and now I can still hear the sound in the back ground but colored stripes up and down the entire screen. Why is that and what happened?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@skully01 we need to see what you see so post some good pictures with your QUESTION iFixitでの質問に画像を追加する方法
The most likely cause with that you are seeing, going by your description alone, is a bad T-con board. Next suspect would be a bad main board and finally (hopefully not), it is a bad panel.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marshell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 93
