location of cmos battery on a toshiba C55D-B5310 laptop
where is the cmos battery on toshiba C55D-B5310
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ray Cisco it does not have one. This computer uses the regular main battery for this purpose. It also uses a capacitor for retaining some of the settings. That is the reason why removing the battery always results in a clock reset however settings such as CMS/EFI boot remain.
このアンサーは役に立ちましたか?
I found the template where it would have been, but, no battery or battery holder or any kind of connection. Who would have thunk????
このアンサーは役に立ちましたか?
@marinade1 CMOS batteries have gone the way of the Dinosaur. Extinct! All regulated and saved via caps and IC's
@oldturkey03 My MSI and HP (EliteBook) still use a CMOS battery. I like it that way since the CR2032 is more proven the capacitor saving method.
My concern is machines which are voltage sensitive like my E7440; it may not be as easy to score one like my i7 edition of the system for parts and quickly get it up and running. The CMOS RAM is very easily corrupted on the 7440 to the point I'd change a battery at 2.5V to avoid a no boot issue.
過去 24時間: 1
過去 7 日: 14
過去 30 日: 63
今までの合計 3,704
