What is the right type of MOV converter capacitor as it blowed up?
I bought Keurig K- Elite from Costco and took back to Singapore. The converter capacitor/ varistor blowed up with mistakenly plugging 220v directly.
Can anyone help advise on the replacement part number as no clear marks can be distinguished from this burned one? Thanks.
BTW. I already bought a 110-220V converter to be ready after Keurig fix.
3 件のコメント
Hi,
What are the voltage (V) and power (W) specifications as printed on the model label on the machine?
This will help to determine what value MOV is required.
What is the full "board" number of the board in your pictures? I can only make out 2628 Rev A.
Maybe searching for the "board number" online may give results. Worth a try anyway.
Also hopefully you meant a 220V -110V converter?
jayeff さんによる
Thanks. The spec of the model is 120V 60Hz and 1470W
The board number is PT0000002628 REV A . Which unfortunately I can not Google out anything.
Yes the converter is 220-110.
chai chaiqinglink さんによる
Hi I have exactly the same problem, do you solve it ? only by the MOV ?
You don't know if it has a fuse as well?
mariofl82 さんによる
