メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
20回答 すべてを表示
Need advice on Tcon board repair
I am in process of repairing a tcon board The number is . ( T370HW02 V402. Cntrol BD 37T04-C02 ) I have a problem with the IC U201 ( AS15-F ) . There is 4 bits on the board missing were pin no`s 1, 16, 17, and 48 soder to is missing as in picture . Does anyone know were these lead to on the board so i can repair it properly , I am enclosing pictures so yous can see what i mean also a diagrahm to see ,Thankyou in advance as i don`t understand what the x,x,No ,Mo. means.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
@moggy01 not sure how you posted your images but can you repost those in a higher format and larger size. They are relatively small and when enlarged become unfocused. From what i can see, and I am old so my sight isn't great to begin with, it should be possible soldering jumpers across the destroyed solder pads.
さんによる
Thankyou oldturkey03 hope these other pics are ok as i just need to know were to join wire to from the pins i mentioned , 1,16,17,48. Thnx again. See my answer for pics
さんによる
コメントを追加
1 件の回答
最も参考になった回答
画像の内容を見る:
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
moggy01 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 906
