メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたTV用ゲームコンソールです。PlayStation 4 Slim (CUH-2000シリーズ)はSP4の薄型モデルです。2016年9月7日に発売されました。
569回答 すべてを表示
Ps4 Controller Turning weird colors
My ps4 controller blinks purple when I turn it then goes to normal and when I try to charge it it turns red instead of orange and no it's not because of a game, it does this in the menu and even when its turned on please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Same thing happens to me every time
And I tried different usb cables but it doesn’t work
It just keeps flashing different Colors faster than the human eye
さんによる
コメントを追加
7件の回答
its normal for a ps4 to do that wile charging, try updating it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It is not normal lmao when you turn on the controller it's supposed to blink blue not purple and when charging it's supposed to be orange not red
さんによる
コメントを追加
I have the exact same issue. Whenever I charge it I can get orange but slowly it seems to move and the connection goes to a red colour slowly and also whatever colour it is it also blinks vividly constantly which indicates for me it's not connecting 100%. I left it for 20 30 mins and then when I turned on it was a purple light and would go blue then just turn off. I'm thinking the charger port is screwed or the charger isn't doing enough for it to even charge that much to the point it's nearly completey drained the battery and it only has enough power to show the led bar as purple then turn off. That's all I can figure out so far. If I can find anything else I will lyk
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I think this mostly happens due to linking it to a non-ps4 Device, I got this when I disconnected my ps4 controller from my phone, it has no way to detect battery, so it just bugs out the light And wont connect
charging
holding ps button
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It got better, I just plugged it in and wait and it’s starting to shift to yellow
さんによる
コメントを追加
This happened to me too after I messed with the wire you connect to the light bar and battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Open %#*@ controler tight central screw on board thats it!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My problem is kinda similar but my controller flashes different Color’s faster than human eye
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem and it may be due to a deffective battery you may have to get a new battery or contoller
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
BunkBunk さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 31
過去 30 日: 152
今までの合計 6,476
