メインコンテンツにスキップ
Model番号 A1225 / Mid 2007とEarly 2008 / 2.4, 2.8もしくは3.06 GHz Core 2 Duoプロセッサ
435回答 すべてを表示
using panel as external display of iMac 2009
So I want to use my 2009 mac as an external display. i found the panel to be LM240WU2-SLB2. and i bought this board https://www.aliexpress.com/item/32973681....
When i connect the panel to the board I get a green light suggesting it is getting signal but the display is black. I am thinking that is because the board kit doesnt include inverter.
Thing is I am not sure if this requires an inverter as according to panellook.com it says it is with inverter. http://www.panelook.com/LM240WU2-SLB2_LG...
So my question is: Do I need an inverter for this panel? And if I need an inverter I am not sure which inverter to get. pls suggest. thanks.
Update (02/14/2020)
I've looked at this post but none of the links posted in the answer work
Can I Mod an early 2009 24" iMac to external monitor?
And some other sellers of the board have this weird contraption which they are not selling along with the board and I am not sure what it is. https://www.aliexpress.com/item/40002754...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@sidshekar your monitor uses CCFL backlights. Yes, you do need an inverter and the kits you are linking to in your question, do not show that you are having an inverter connected. Here is the data sheet which list the inverter properties on page 7 LM240WU-SLB2_1 Data Sheet
Take a look on here Universal Backlight Inverter to see how to connect an inverter to the CCFL. Post some good pictures of how you have your kit( instead of stock pictures) set up.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@oldturkey03 Hi. Thanks for responding.
So I have figured out what the problem is. For my display the inverted is on on the display as correctly mentioned on the panellook website. Also on page of your document it mentions that inverter block is present and requires 24v. So I dont need an inverter( hopefully if it not busted)
The panel wasn’t lighting because it needs a separate 24V power to inverter. The display board also needs power but it takes 12v input so i’ve actually purchased this power board (which I refered to as the contraption in my message earlier) (https://www.aliexpress.com/item/32973681... ) which will power the display board and the inverter with 12 and 24 volts respectively.
I will update the result once I get the power board! Cheers!
さんによる
Sorry here is the link to the power baord. https://www.aliexpress.com/item/32838768...
さんによる
@sidshekar that could just work with that contraption. Just careful because the panel may just get its voltage from your universal driver board
さんによる
Ya I just have to be careful that after connecting the display board to the power board I shouldn't connect the barrel power as well :D. That sure sounds like a recipe for disaster...
さんによる
コメントを追加
回答を追加する
siddharth shekar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 16
今までの合計 444
