メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
iPhone stuck in boot loop after repair
So I got a couple of iPhone 7’s in which I replaced the housing, battery and screen to refurbish them.
Upon switching the devices on, both units are going into boot loop.
I’ve tried restoring the device on my mac, but am getting error 9.
I’ve also tried;
Disconnecting camera/proximity sensor
Disconnecting home button
Connecting old screen just incase I got faulty replacements
Is there anything I’m missing? I heard it might be Audio IC, but if the device cant boot at all, this can’t be it, right?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
最も参考になった回答
Had this issue with an iPhone 7 and the front camera-proximity etc. was faulty. I also disconnected it but it kept looping. I think that the iPhone 7 does a pre-boot check and if there is a problem detected, it won’t boot. In my case i replaced the flex cable and everything was ok. I also had the same again and the fault was on the flex cable of the home button
Good luck
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It might be worthwhile for me to order a replacement flex cable just to try.
I thought if it was the sensor that it would turn on unplugged. But if it worked for you, it's worth a shot.
They're not that expensive anyway.
さんによる
コメントを追加
This sounds like an audio IC repair gone wrong. They have applied to much heat to the board resulting in the baseband CPU solder balls bridging.
Check around the big audio IC and you will find it has been worked on. If I where you I would try and get my money back.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
No Audio IC was done. Only housing replacement, battery and screen. Done by myself. Units were in working condition before hand
さんによる
Put board back in old housing use all the old parts. If the board boots start swapping parts to you find what is faulty. Especially dock and battery.
さんによる
コメントを追加
Try to disconnect as much as possible to keep the phone running, which means either only display flex, battery and power flex (or turn on with tweezers) or power flex, battery and charging flex to restore via iTunes. iTunes is very unreliable, so it might work to use another computer without an Antivirus software.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if its doing a supper long bootloop im willing to bet its audio ic but the device should still restore via itunes depending on how bad it is.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When changing the housing, did you remove the flex that is attached to the housing itself and maybe damaged the flex? Have you checked charging port for dirt and are you using original cable to connect to itunes? I thought error 9 was a connection error.
I had an ip7 on boot loop and it was due to the proximity sensor/camera flex.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luke Doran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 115
