メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
Powers up with sound but picture takes 15 mins to appear
Sanyo DP26649
Powers up, sound comes on but takes about 15-20 minutes to show picture. Its been doing this for 5 years. Other than that it works great. Id like to keep it if it’s a simple fix. Can anyone lend any advice? Thank you in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@kcstarr when the screen is dark and you are waiting for it to come on, shine a flashlight beam at an angle against it. See if you can make out shapes, silhouettes etc. If so you know that this is your backlight that is the issue. After that you will have to check the power board and the main board. Check for obviously damaged parts or loose connections. Post some pictures of your boards with your question so that we can see what you see. For now this sounds like either colder solder joints, bad capacitors or bad power Mosfets.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi @kcstarr ,
Here’s a image taken from the service manual showing the Sanyo Troubleshooting Guide (only for 2009 models) and for the DP26649 (except DP26649-03) model showing the Green Power LED is on but the LCD backlights are not on troubleshooting flowchart.
(click on image to enlarge for better viewing).
Hopefully it is a help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kclement20 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 54
