メインコンテンツにスキップ
The LaCrosse debuted in late 2004 as a 2005 model, replacing the Century and Regal.
2回答 すべてを表示
Keep getting a starting system disabled on 2006 Lacross
I keep getting a starting disabled message while driving my 2006 Buick Lacross. And it shuts off. Disabling everything while I'm driving… power steering and engine. I let it sit for a couple of minutes after I manage to pull over and then it starts up again. I also get a couple of other messages like service IBS system soon and service traction system also when this happens. Any clues?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I had the same problem but it didn't shoot out a code.Dealership had it for a whole day before it ran a code.Turned out it was the PCM.
さんによる
コメントを追加
3件の回答
選択されたソリューション
Donna brown you got a whole lot going on here. I would suggest that you take it and have the OBD scanned. Generally it is the theft deterrent system that generates the message. Sometimes after the battery has been changed or the battery has been jumped a relearn procedure needs to be performed. It is also possible that this is a failing crank sensor. You should be able to find the cause or issue by scanning the control module for the history codes.
Security Relearn
  1. With a master PASS-Key III key, turn ON the ignition, with the engine OFF.
  2. Observe the STARTING DISABLED DUE TO THEFT message on the driver information center (DIC), after approximately 10 minutes the STARTING DISABLED DUE TO THEFT message on the DIC will turn off.
  3. Turn OFF the ignition, and wait 5 seconds .
  4. Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes .
  5. With a master PASS-Key III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password. IMPORTANT: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. from here
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank You I will check that out.
さんによる
Hello, when I stay this procedure the “starting disabled” message never goes away. Evens after waiting over 20 minutes it stays there.
さんによる
my starting disabled message isn't going away, what do I do?
さんによる
コメントを追加
Starting disable never went
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Donna Brown, did you make a new key or lost the original key and made a new copy. The message you have normally indicate you are using a new key and it needs to learn the new key transponder. the steps provided by oldturkey03 are the proper steps to introduce the new key to the car.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Donna Brown さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 41
過去 30 日: 249
今までの合計 7,873
