メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Battery stuck at 1% after replacement, however shows 100%
Hello.
Recently got an iPhone 5s in my hands with a really weak battery so decided to replace it and give the phone another life.
After the replacement battery is stuck at 1% and after few seconds of use the phone would turn off. At the same time if I connect it to power source the battery jumps straight to 100% and stays even if I disconnect the cable but would turn off anyway after some seconds. Like the phone thinks that battery is full but actually it isn’t (or maybe it is?). Seems to be warming up while connected to charger so I suppose actually it is charging? Reattached all the cables, tried DFU restore - didn’t help (weird that the phone would go off even with the cable after some time, but it won’t turn off during restore), tried to charge it overnight while turned off, but at the morning it was still on 1%.
Could it be faulty U2 Tristar charging IC or maybe someone have other ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If you haven’t already i would start of by testing with the old or another new battery, but you have probably already done that. Next step would be to check the components right next to the battery connector. You might have accidentally removed something from the PCB when prying the battery connector, i’ve made this mistake ones and it’s one of those things you do once as a repair technician and never again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
martins.eniks さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 222
