Roller brush doesn’t turn - Shark Lift-Away brand
I have a Shark Lift-Away, the brush has stopped turning. I have cleaned it, etc.
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
このアンサーは役に立ちましたか?
That instruction is basically clean it, it doesn't have an answer.
Mine just doesn't work no .atter what I do
have check all obvious problems but brush roll wont turn
このアンサーは役に立ちましたか?
I'm having the same issue. Is there a reset button for the beater bar(brush roller)?
Brand new right out of the box will not pull or push spin brush does not work.... WTF is the problem with this vacuum
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 38
過去 30 日: 163
今までの合計 4,327
My roller also stopped working. It would be nice if you could remove brush to see if there is hair wrapped around where the brush connects.
Yazmin Kuball (Traveler) さんによる
@yazminkuba18603 You can remove the brush, but it's not just a matter of snapping open a couple of latches on these machines; there are like 10 screws that have to be taken out but it is doable.
Shark Navigator Roller Brush Replacement
Jerry Wheeler さんによる
