メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2620回答 すべてを表示
Pixel "stains" of different color on top part of the screen
Hi all, yesterday I noticed that the upper part of my tv started to have some “stains” of pixels showing colors different than what they are supposed to be.
Normally these stains are of a light blue color when on the screen there is a bright image, then they turn black if there is a completely red background and when there is a black image they are completely unnoticeable.
I also noticed that if I look closely with a flashlight these stains sort of remain even when the tv is turned off.
I never spilled water on it or anything, actually i never even moved the tv in 4 years.
Any idea what it could be? (TV model: Samsung UE55JU6400)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi @vladp ,
Have you tried adjusting the picture Zoom or Custom position up and down to see if it resolves the problem?
Go to (MENU/123) > MENU Picture > Picture Size > Picture Size > Try Now
Here’s a link to the user manual. Scroll to p.121/194 (pdf file numbering at top of document) to view all the options for moving the picture so as to remove the line from the top.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
it could be that air is getting into the lcd
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Gage, Whaaaaaat? Can you please elaborate on that?
さんによる
I have seen that Samsung phones have had air get in between the LCD layers in cases similar to this
さんによる
This could probably be the cause, after a while I noticed some screws on the back of the tv were a bit loose and there was a small gap between the panel and the rest of the tv.
さんによる
コメントを追加
回答を追加する
Vlad さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 20
今までの合計 558
