メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3473回答 すべてを表示
GE WSSH300G1WW is not spinning
My front load model GE WSSH300G1WW is not spinning. it drains into a basin so i know the pump is pumping out water. it then tumbles back and forth for a while . No high speed spin and clothes are still soaking wet. Coin trap is clean. Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Start with the basic troubleshooting tips on page 18 of the Owner’s Manual (link below). For “Washer won’t spin” the manual says the possible causes are 1. Washer door is open, 2. Dispenser drawer is open, and/or 3. Load is too small.
Next, check if the washer is giving off an error code . Essentially, if an error code occurs, the lights will flash and it will beep a number of times. The number of flashes is the error code. Then, it will pause for two seconds, and then repeat the error code. See page 23 of the Service Manual below for deciphering the error code.
Next, go to page 7 of the Service Manual. Perform the diagnostic test. You’re most interested in paragraph 9 for the spin cycle. This will manually put the washer into spin, and perhaps throw an error code for you to diagnose.
Finally, go to page 26 and perform test 9.
Most likely, you problem is either the door switch assembly (see pages 12-13), the inverter or the motor (see page 21). Hopefully, you will have a clear error code. If not, test 9 on page 26 will be your guide.
  1. REF - Owner’s Manual: https://data2.manualslib.com/pdf/6/597/5...
  2. REF - Service Manual: https://data2.manualslib.com/pdf3/78/772...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
William Reed さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 27
今までの合計 1,903
