メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
iPhone 8 display jumping around, already tried different screens
Hi guys,
Got an iPhone 8 here. The phone is not dropped or water damaged. It has a strange issue. The display jumps/moves around from time to time. If I play the phone for a little while, the jumping will settle down. But after 10 minutes, the jumping starts again. I already tried different screens, both copy and original ones, same result. So it’s not screen issue. I also put the phone to DFU and restored to original factory settings. Restoration was successful, but made no difference. Display is still jumping from time to time. It’s 100% motherboard problem.
I recorded the jumping issue in my youtube video, here is the link:
https://youtu.be/zIuofyEiY0U
I wonder if anyone can help? Where should I start on motherboard? Any feedback would be highly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hey there,
So it sounds like it’s having issues with the orientation sensors such as the gyroscope and accelerometer. If you go to compass and it acts weird and the level tool also doesn’t work, then it’s most likely this. There was a thread a while ago that went into more detail and they’ll probably explain it better than I can.
Simply put, it’s a logic board issue most likely.
Rotation sensor is messed up?!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Andrea, you are absolutely correct. The compass app doesn’t work at all! I’ll check the compass/gyroscope line, see what’s going on. Probably one of the IC chips is faulty. Many thanks for your help, much appreciated.
さんによる
コメントを追加
回答を追加する
phonestore.uk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,777
