メインコンテンツにスキップ
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
20回答 すべてを表示
Can a wet phone still be fixed after I charged it?
so i my phone got wet, at first it worked perfectly but after a few hours it turned off . i thought its battery died so i charged it and now it wont turn on or respond to anything. so can it still be fixed by a professional?
HELP ME PLS
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Yes there is still a chance to salvage a water damaged phone even after it’s been plugged in. However, keep in mind that by plugging it in you are introducing electricity to a board that could have unwanted bridges between components and that can severely damage a device.
Best thing to do would be to disconnect the battery (if possible) and bring it to a repair centre ASAP. Or, if you feel confident enough, try fixing the water damage yourself! Check out this link for some more info
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
so it turned off on me last night and i plan to take it to a repair centre tommorow, is that too long? (also thanks for your answer very helpful)
さんによる
The sooner you bring it in the better. Every case of water damage is different so you couldn't really say when it's too late
さんによる
コメントを追加
回答を追加する
tato さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 126
