power jack problems, any ideas?
the power jack on my acer aspire 5750 seems to be loose. and when i tug on the power cable, the computer just stops charging at all. is this a common problem? and if so, is there a way to fix it?
Ethan Rhoads not sure about common but it does happen. You can repair the jack yourself. Use this document acer_aspire_5750_5750g_sm.pdf page 3-30 to get to the jack etc. It is soldered onto the board and will require some soldering. Check this video for more info.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 159
