メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
Why won't my iPad turn on?
Since my iPad turned itself off, while I was using it, I’ve tried resetting it and connecting to computer- neither have helped. When I hold in power and home button the logo screen flickers on, for varying amounts of time and sometimes with part of the screen darker then the rest, and then turns off again before the lock screen.
Update: I managed to turn it on for a few moments, the screen was very dark except around the home button where it was lit up more- it then switched itself off again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
You have to determine if this is a battery/charging issue or something else. Try these steps to help isolate the issue (in order):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units. Does an iTunes enabled computer recognize the device?
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. You can use a USB Ammeter to determine if the device is really drawing current when it says it's charging. If it isn't drawing current, then it could be a bad charge port or battery.
At this point, you need to get back to us with more info on your troubleshooting. You may also need to start replacing stuff, which means opening your device. Check out this guide to see if you are comfortable with the work required.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
it has died or the batry died
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it has died and you can take it to i place to fix it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
particleman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 452
