メインコンテンツにスキップ
A series of 40 inch LCD HDTVs by Sony.
20回答 すべてを表示
Sony Bravia KDL-40w600B TV Display Blinks once every second.
After about a minute display starts blinking.
Cannot access self diagnosis feature.
I will open it up and have a look at the boards tomorrow.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @mike8888,
Looking at the service manual I’m wondering if there is a faulty backlight CCFL tube in the panel.
p.9 of the manual indicates what the Standby LED count pattern is for a backlight failure but only refers to the “panel module” as well as what boards supply power etc and presumably you only get this problem if the CCFL has failed entirely and is not blinking on and off.
Just my thinking on this.
さんによる
Thank you Jeff. I will be checking that first.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@mike8888 your panel is a LED backlight panel. If your Display actual appears to turn on and off and thus looks like it is blinking, you may have issues with the backlight array. Your TV should have an LD board and once you have your TV apart post some good pictures of your boards etc.. Clarify for us that you get sound etc. or that you at least checked if you maintain a picture during the blinking, by shining a flashlight beam at an angle against the display. Personally I’d check
power board output
LD board
LED backlight array
My number one suspect here are the backlight strips but measure the voltages between main board and LD board etc.
iFixitでの質問に画像を追加する方法
Update (01/29/2020)
@jayeff possibly a generic message. I've added the SM to my answer for verification Sony-KDL-40W600B-and-more.pdf Hopefully I’ve read it right :-)
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thanks oldturkey,
I was able to do the self diagnostic test but it found no problems even with it blinking. It ran a sound and picture test as well and brought up a clock scene which does not blink at all. At the end it said if I saw no issues it's probably a content issue.
I also believe it's a ccfl issue. I can take pictures of the boards tomorrow.
Thank you.
さんによる
@mike8888 it's an LED backlit TV. There are no CCFL's :-)
さんによる
Hi @oldturkey03
I must have been looking at the wrong service manual (that I linked above. It calls it a LCD TV and not a LED TV) as it mentions precautions when handling the CCFL under the Safety Notes:
"1-2. Caution Handling of LCD Panel....
6) Disconnect the AC power when replacing the backlight (CCFL) or inverter circuit. High voltage occurs at the inverter circuit at 650Vrms"
unless this is just a generic warning for all their models which would seem strange. Same model number, different chassis number perhaps??
Cheers.
さんによる
Hi @oldturkey03 ,
Fair enough.
You read it right ;-)
It is hard to miss the "LED Backlight" designation in the block diagram on p.6
The manual I linked states "common information" but though the model number is the same it has a different chassis number to the SM that you posted.
Guess it might depend on which chassis it is but I think that your SM is probably the correct one.
Cheers.
さんによる
コメントを追加
回答を追加する
Michael Shaw さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 2,523
