Tv has sound but no picture
What's the cost for a new ccfl light cause one is completely red idk if that's good or not and it's from 2007 the model # DP32648 the serial # B8300237483975
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @emu21 ,
I’m wondering as the CCFL tubes are inbuilt into the panel that they cannot be easily replaced.
Here’s a link to the service manual for the TV.
In the spare parts section there is no mention of a CCFL tube as a spare part.
However there is a mention of the panel. Part number T315W02 VC01.
When you look at the datasheet for the panel, there are two ccfl tubes in the panel but there is no mention of a part number either.
You may have to open the set and remove the panel and see if you can access the faulty CCFL tube and hopefully there may be some info on it which will help you locate a replacement.
It may be easier to get a replacement panel, although given the date of release of the panel, they would most probably all be pre-loved and the ccfl tubes may be nearing the end of their life cycle anyway
Hopefully this may help a bit.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 95
