The sound has a reverb like a blown speaker..
The sound appears to have a reverb like a blown speaker. Is it fixable?
Hi @lejones ,
Check the audio output from the headphone socket at the back of the TV and listen if it sounds distorted as well or connect a receiver via the audio out connections (remember to change the audio settings in the TV to “TV speaker off”) and check.
If it still sounds distorted then there is a problem with the audio amp or the audio processor in the TV.
If not then most likely it is the TV speaker.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,987
