Upgrade Wifi card on ASUS X555L
I want to upgrade the wifi card that its can be support on 5Ghz WIFI , what model is recommended?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
The following WiFi / BT module is shown in the parts list for an Asus X555LA so at least it should work
It is an Asus 802.11A/B/G/N/AC WLAN+BT4.0+HS module . The part number is 0C011-00110200
If you search online using the part number only in the search term of your browser, you will get results for suppliers of the part.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
thank you so much for the information! ill find out =]
過去 24時間: 0
過去 7 日: 5
過去 30 日: 40
今までの合計 4,903
