Craftsman LT2000 Kohler 17.5hp Motor - Trouble Idling, Power Issues
So can anyone diagnose what may be the problem with this mower? I inherited it and the previous owner reported it was very hard to start and took 10-15 minutes of cranking before it would catch. I took apart the carburetor and cleaned that real well, replaced the spark plug. It drives around ok but when at the top of a small hill started losing power and nearly stalled out. When I finally got it to start it was very loud and just my opinion sounded like what I think is a timing problem, but I apologize for the vague question I’m not sure where to start. Can someone tell me if that’s a good guess, how to fix it, and what other things I might look for if that’s not the problem?
https://www.youtube.com/watch?v=lcJW9KzR...
https://www.youtube.com/watch?v=pVGS0ike...
Update (01/24/2020)
This is my motor information
この質問は役に立ちましたか?
3 件のコメント
Is your muffler plugged or your breather
Joan Porter さんによる
If you hear a clinking or clanking noise internally that's definitely not normal and sounds like metal against metal which will at some point be fatal to the engine . Some engines won't idle or run very well if they are low on oil also . Safety feature so it doesn't get blown up .
tnrebel Hix さんによる
The EPA has required the manufactures to pass clean air emissions in the small engine industry . They are running the engines so lean that after some break in periods they run like crap or are hard starting . Most no longer have any adjustments for the carburetor . The small hill issue very much points to that . If your dealer can’t or won’t fix it , lookup a new carburetor part number on kohlers web site . Use that part number on Ebay to find an adjustable replacement carb . The other option is use jet drills and make a larger hole in the main jet (jets ) . Not recommended as an owner operator fix .
Jim Darnell さんによる
