メインコンテンツにスキップ
Midrange laptop released by Asus in 2014.
7回答 すべてを表示
What mSATA card do I need for this laptop?
There is a port labeled SSD on the motherboard, near the existing SATA drive. It appears to be an MSATA slot. What size will this laptop take for the msata card?
Update (01/21/2020)
This is a picture of the MSATA port on the motherboard
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
OUCH - it’s half height mSATA! Half height comes in much worse capacities (relative to full size mSATA, which is the size of a industry standard WWAN card) so your options are limited here. Asus probably intended it be used for a 16-32GB caching SSD since they used the crappy version.
Unless you have an oddly specific need, stick to using 2.5” SATA in this and consider the mSATA dead end unless you want a 250GB boot SSD at most - and even then it’s a matter of when those stop getting produced and go up in price, at which point the mSATA option is dead. The other issue is half height drives are hard to come by (relative to full height), so drives aren’t as available - for less capacity to make the situation worse.
Case and point:
You got burned with this laptop. Even my E6540 used full mSATA since Dell wired it up for both WWAN and mSATA, despite the standard being thoroughly obsolete in 2013 because they didn’t implement M.2 2880 when that was the defacto standard when that laptop was released.
Hopefully you’re okay with spending $116 for a drive with a reduced write lifetime compared to mSATA (which is already worse then 2.5” SATA) AND paying about as much as we did for 256GB drives just 3-4 years ago. Compare that to a 2.5” 512GB SSD (Silicon Power) and you’ll see the problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Sherwin Finch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 830
