メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
None of the microphones working after repair
A friend smashed his phone up pretty bad. Bent, broken front and back. Ordered OEM complete housing with components, and a screen. Pretty simple repair usually. Everything went well except bot neither microphone work at all (normal phone call or on speakerphone) no one can hear me on the other end. The test of the components seem to work find on each flex that shares the mic which is odd (camera, charger port, etc) which I would think eliminates the whole cable being bad. Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I think it may have to do with defective, incomplete flex cables included in the housing I ordered. Anyone have any input on this? Photos attached. It appears chips and solder connections are missing from new cable.[image|1981763][image|1981762]
さんによる
コメントを追加
1 件の回答
ベストアンサー
If the phone has been bent there is a good chance of broken traces and or cracked solder balls under either of the two audio IC’s or if you are unlucky enough the CPU.
 If you have ruled out parts this would be the next road to go down.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Austin Harris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 126
