メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Display and touch is not working after connecting Front Cam FPC.
I have a iphone 5s whose display and touch is working perfectly fine without the Front cam FPC.However,when I connect my front cam FPC, there are lines on display and touch is also not working.I have already tried with 3 working displays.same issue with all.
All diode mode reading of my frontcam FPC connector is matching with a working board.
I know there are CUMULUS_TO_PROX_TX_EN_BUFF,CUMULUS_TO_PROX_RX_EN_1V8 & 45_PROX_TO_CUMULUS_RX data lines are connected with Cumulus and sage.I am not mentioning powerline rail,if there has been any fault it would have been detected by diode mode. I have only tried with cold method i.e without powering the phone. Can any one help me to troubleshoot my problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello Repairman
Just an idea, but I had similar problems finding the touch connector damaged (vertical on the left side). It could be that it created a bad connection, but I don't understand why it affects another connector.
It is a very weak connector and easy to damage / deform.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
THE REPAIRMAN さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 67
