メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
iPhone X: screen black but touch works and the glass isn't cracked
After a fall, exactly a 1 meter fall that touched the floor with corner of the phone, the screen turned all black, but the crazy thing is that the screen is not broke and the touch works.
On internet I didn’t found nothing like that, can anyone please help me?
thank you in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
Hello Kristian
The first thing would be to open the iPhone and make sure everything is in place. Attentive to the necessary tools, they are not usual screwdrivers.
The iPhone X screen is OLED, this makes them more delicate than previous models. OLED screens are easy to break without breaking the glass too. With a good blow the OLED panel could be damaged and stop working while the glass is intact.
For this you must change the screen, there is no other solution.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you a lot!
さんによる
コメントを追加
最も参考になった回答
either something has dislodged inside the phone which needs connecting back together, unlikely as there’s small panels holding most things down, or parts of the digitizer (the part that's lights up the screen) behind the glass have broken in which case you need a replacement screen as they come together as one.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
thank you! waiting for other answers!
さんによる
@kristian.loshi no problem hope you get it sorted
さんによる
コメントを追加
It Could be that one of the flex cables that connects the iphone X screen to the phone is snapped / dislodged, open the phone and check note that you will lost waterproof capabilitys if you open the phone up alternatively you can take it to a repair shop which will diagnose the problem for free after that you can see if you can repair it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
how much would it cost to get it replaced?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kristian.loshi さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 68
今までの合計 4,161
