Why is it getting so loud?
While it's spinning the cloths there is a loud almost rubbing sound
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. ... If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 34
