メインコンテンツにスキップ
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87回答 すべてを表示
Driver side Turn signal doesn’t work.
Looking for some help it’s a 95 accord lx 2.2 automatic and I could really use some help not very car savvy but I’m willing to learn so please be detailed and thank you in advance but yeah I replaced the bulb on the signal next to the headlight and the one on the bumper “looks” fine what next?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi @notreally ,
Does the instrument panel left turn indicator light work?
Can you hear the turn signal relay operating in the cabin when you operate the combination light/turn signal operating lever to turn left?
If you can’t when you operate it to turn left but you can when you operate it to turn right then you have a faulty turn signal lever switch or a wiring problem between the switch and the lamps.
Do the driver’s side turn signals work when you operate the hazards light switch?
If they do then you have a faulty turn signal lever switch.
If they don’t then you have a faulty wiring between the lamps and the signal turn switch or the hazard switch. I don’t know where the wiring runs to first from the lamps.
Here are two images that may help.
The first is the circuit diagram for the lights and the second is how to test the combination light /turn signal switch to check if it is OK.
(click on images to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Check your fuse box for a blown fuse. Your owners manual should tell you which one to look at.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
double check the bulb, the harness that plugs into the bulb for any dirt or damage, fuse box for blown fuse and failing that the wire itself for any breaks.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Luis M さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 28
今までの合計 1,864
