メインコンテンツにスキップ
冷凍庫を含む冷蔵庫の修理と解体ガイド。
freezes up so only the freezer work
I have a 2018 built in GE monogram french door refrigerator and every 2 or 3 months it freezes up so only the freezer works, GE told me it was my fault and we probably were not closing the freezer door completely, I have methodically checked this and it still freezes up so assume it is defective, my warranty runs out in August so need this fixed, any one had similar problems
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please give us your exact model number.
さんによる
コメントを追加
2件の回答
ベストアンサー
Russell, I’d suggest calling GE back. Doing any repairs yourself could void your warranty. I would request a different technician to come out to diagnose the issue. If you aren’t shutting the door completely, your freezer wouldn’t be freezing properly either. Most people will notice the door open because that refrigerator has an alarm that beeps. I’m not buying what the technician told you. Especially if you’ve been making sure the door is closed.
The issue your experiencing is typical for a defrost problem, gasket issue or a fan motor. Either way, it is all under warranty and you should not have to pay for repairs
You have an expensive, top of the line refrigerator and your warranty is to protect you from costly repairs. The right technician will be able to solve the problem. Unfortunately, not all technicians are the same. Request a different technician or even request the lead tech. People do it all the time. Use your warranty while you can.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Depending on the model, which you didn't provide there could be five possible problems:
  1. Main board
  2. Defrost time
  3. Defrost sensor
  4. Defrost element
  5. Fridge needs to be pulled out and coils vacuumed and cleaned
When I had the problem, it was ther defrost element. If everything else is working, I doubt it's the main board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I probably should've said at least 5 possible problems. I'm sure I overlooked a couple.
さんによる
コメントを追加
回答を追加する
Russell Boxall さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 68
