I need to change out the power port. How?
I need to change out the power port of my Harman. Just the part the plug goes into and not the aux or ac adapter. How do I do that and where can I find that piece?
The power supply is 19VDC and I looked at the power cable connector. This is a VERY common DC plug and jack combination used on many AC-DC power supply adapters (think laptops!). The main thing is to check the diameter/length of the plug barrel and match it up to the replacement part. Newark Electronics or Digikey or Mouser among others will have this part for you. You may have to adjust the mounting etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 591
Can you post a pic of the port?
drmdolfan さんによる
