Yellow Ink Shows Full but Not Printing
Added new ink and all look good, except Yellow ink does not show up at all on Nozzle Check. Yet shows as Full on Ink Monitor. Is it the Ink cartridge or the printer?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The yellow nozzle “might” be plugged. Wherever the print nozzles are, carefully wipe them off 2 or 3 times with a paper towel wet with isopropyl alcohol. This Usually dissolves the clog.
このアンサーは役に立ちましたか?
I have both an Epson R1900 and an Epson P-600 and it is always the yellow cartridges on both printers that have problems. I wonder if the pigment in the yellow cartridges has a higher tendency to gum up either the print head or the cartridge.
Many times when the yellow cartridge stops working, swapping it for a brand new one works instantly, no cleaning required. This makes me think it is definitely not a printer problem, but a cartridge problem, specifically for yellow pigments/inks.
このアンサーは役に立ちましたか?
過去 24時間: 25
過去 7 日: 158
過去 30 日: 651
今までの合計 15,698
