メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年7月に発売された、モデル番号{A1989 / EMC3214}のMacBook Pro13インチモデルにはクアッドコアi5と i7 を搭載しており、グラフィックにIntel Iris Plusが統合されています。
Is it possible to recover data from MacBook Pro 2018 with a T2 chip
I have a 2018 macbook pro which has been damaged by water. Luckily the T2 chip and ssd are intact. I know the data recovery port has been removed from the motherboard by apple. It is possible to recover the data? Can I do it on my own or I have to send it to a professional. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
最も参考になった回答
Yes it is possible though it requires that the T2 chip is able to power on and you are able to put the machine in DFU mode. However because Apple is Apple you need access to GSX and AST2 to be able to start the diagnostics suite which puts the T2 in a target disk mode. I am not aware that anyone has made any 3rd party solutions for this. So I think your best option is to work on it until you can confirm that it shows up in dfu and then bring it in to a aasp so they can run the tools to transfer the data.
These support pages has more info about T2 dfu with use of apple configurator 2
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Same happened to me last month, Did you succeed recovering your data? Please say yes?
さんによる
コメントを追加
According to this article you cannot recover the data by yourself.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’ve bought a macbook pro a1990 on ebay with activation lock is it possible to remove.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not unless you can get the previous owner to remove it from their iCloud account.
さんによる
コメントを追加
I believe it would be possible. I also have a MacBook Pro 2018 but it stuck at a black screen. I was so worried about my computer files. I looked through many pages and most of them indicated that the T2 chip makes it almost impossible to recover data from a damaged Mac.
I was so desperate until I saw this page. It recommended a data recovery tool called iBoysoft Data Recovery. This was my last hope. So I went ahead bought the software and tried it, too panically to test demos. Results maybe 60% of the files. While iBoysoft Data Recovery did get some of my files all the databases were destroyed and none of my layered .afphoto files were recovered so lost a lot of man-hours. I’m on the road at present so my backup procedures were not as strict as they should of been so yes everything is my fault.
I hope it will help!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
May I know how could you operate your Mac with iBoysoft when the Mac was stuck at a black screen?
さんによる
コメントを追加
Hello, maybe you can just try a third-party data recovery tool, I think it’s the fastest way to recover your files. You can use Bitwar Data Recovery, it offers a 30-day free trial without space limitation. Hope it still helps!
画像
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This software is sus, reading the reviews it seems like none of the people actually speak English; sounds like bad Google translate from another language. I'd be wary.
さんによる
コメントを追加
Hey,
I have the same problem. I have 2019 MacBook Pro 16 inch 512 gb (I think it has T2 chip), and it has been damaged by water unfortunately.
I took it to apple and they said they have to change the motherboard totally as CPU is broke (short circuit). but if they do change the motherboard , I will loose all of my data and files. can anyone help me if I can have my datas from my MacBook. ?
ps : My MacBook is not working at all.
Your help is highly appreciated.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
hey ugurcan, did you find a solution? if so please let me know.
さんによる
Did you find a solution? I have the same issue
さんによる
コメントを追加
回答を追加する
Leon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 17
今までの合計 4,924
