メインコンテンツにスキップ
AppleのMacデスクトップもしくはラップトップコンピューター用のオペレーションシステムです。
70回答 すべてを表示
I can not restore devices after updating to Catalina.
I have restored phones before in iTunes, but the restoring process is now done through Finder in Catalina. I tried restoring both and iPhone 8 Plus and an SE, but each would get the the extracting stage and go out of recovery mode right as the process was about to finish. I tried restoring them through iTunes on a Windows computer, and I had the same problem with the error 4013. I used a genuine Apple cable that was in good condition, and I tried other cables as well. I also tried just restoring from an already download IPSW file, but this had the same result. I called Apple after my initial attempt in November, and the rep I spoke to told me the engineers were working on the problem and that I should update the OS when a new update comes out and try again. I updated the OS and just tried again this week, but I got the same result. I was wondering if anybody else had this problem or knows if there is a solution or if it is still an Apple issue. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Yes I did! I talked to 3 people at Apple. No one could help. I called for a forth time and the rep knew exactly what to do. She came into the computer and it was done in 15 min. I have no idea what she did but it fixed the problem.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ok. Did she do it over the phone, or did you take it into an Apple store? If I have to take it to any Apple store, I can, but I don’t live close to one.
さんによる
コメントを追加
回答を追加する
Alec Thompson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 958
