メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
iPad turns on when plugged in but wont charge
I plugged my ipad into the wall when it is on and wont charge but when I turn it off and plug it in it will power on like it detects the charger but wont charge and also not recognized on my computer
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
I tried 3 chargers 1 of apple 1 after market with certification and 1 with out only 1 that turns on the ipad is non certified 1 ipad dosent respond to any other cable
As far as I can tell it looks good inside the charging port
I can check with 3utools since the computer isn't recognizing the ipad
I sadly don't have USB ammeter to check
I've also tried a battery swap and it still doesn't make a diffrents
さんによる
Most likely the Lightning flex, I change these all the time...
さんによる
same thing happends to me i cant find a fix its been like this for 4 hours
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hello Jayden. When troubleshooting charging issues, I would do the following (in order):
  • Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  • The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  • Change the battery. The battery is the weakest link and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  • If the battery is in good condition, you can use a USB Ammeter to determine if the device is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port. The iPad Air has a well documented history of charging problems. Over time, it loosens within the housing and this causes the flex, at the point where it connects with the port, to crack. This repair requires some micro-soldering.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
I’m having this issue. What’s cost to replace battery.
さんによる
コメントを追加
回答を追加する
jayden gumb さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 91
今までの合計 6,689
