Which Hot Air Unit?
Im looking into an aoyue hot air unit and was wondering which one would be best for iphone logic board repair?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
A heatgun on medium heat is usually your best bet
このアンサーは役に立ちましたか?
you talking a regular heat gun i can use for removing chips off logic boards?
It actually does work, but I would suggest if you can afford proper equipment or have it, use that, many other people here had success using a heat gun, but make sure you are careful of the soldering pads, they can come off
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 364
