メインコンテンツにスキップ
Repair guides and support for Panasonic's Viera line of televisions.
417回答 すべてを表示
Panasonic TX-L37ET5B image freezes, vertical color lines, image fade
Hi all,
I have a Panasonic TX-L37ET5B which does a funny thing : the image freezes for a few seconds ( iI have noticed that a few centimeters on the top of the screen don’t freeze), while I still have sound, also the image starts to fade and some color vertical lines appear on the screen.
Any idea what’s wrong with it ?
I have attached 2 videos .
https://youtu.be/ziQA1XkRR2U
https://youtu.be/hEQz0PTzlfQ
Thanks
Update (01/05/2020)
@oldturkey03 thank you for the fast reply.I have taken some pictures with the boards, but only from one side. I will remove all the board tomorrow and check on the other side as well.
I will also try tomorrow to clean the connectors with some contact cleaner.
If is a bad panel, it doesn’t worth replacing/repairing, right ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
marmotasrl  possibly a bad main board but most likely a bad LCD driver which is part of the panel. Remove the back and check the boards for obvious damaged components. Post some good pictures of your boards so we can see what you see. Double check all wires for proper seating. Remove them and reinsert all the ribbon cables etc. Ultimately this does look like a bad panel. iFixitでの質問に画像を追加する方法
Update (01/05/2020)
marmotasrl  here is the service manual in case you need it PCZ1202001CE
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
marmotasrl looks good. Thanks for the images. That size panel maybe easier to find and may be cheaper than a new TV. Of course it'll depend on where you are located and what shipping etc. will add to it. Do an online search for your panel LC370EUD (SE)(F2)and see what you think.
さんによる
Thanks for the info @oldturkey03 . I've found the panel for 30pounds(I am in the UK ) which is good. Is it a job that I can do home ? ( can't see how to change those). Thanks
さんによる
marmotasrl yes you can. It is not that complicated. I do believe I have a manual for this so bear with me.
さんによる
@oldturkey03 thank you. 1 more question if I may : do I need 1 ore more of those LED strips ?
さんによる
@marmotasrl that is a tough one. See if you can order it as a set. It could be 2 or more.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
marmotasrl さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 10
今までの合計 802
