メインコンテンツにスキップ
This is the Asus - VivoBook X540SA-BPD0602V 15.6", (1366x768) Laptop which contains an Intel Braswell Quad Core N3700 1.6 GHz processor that supports turbo up to 2.4 GHz. It contains 4GB of RAM and a 500GB hard drive.
15回答 すべてを表示
Can I replace the 1To HDD by a smaller SDD (500Go for example)
Hi,
I would like to upgrade from HDD to an SSD but considering the price I wouldn’t mind a smaller drive but I have a doubt concerning the cloning from 1To to 500Go, is it possible ? considering I only have 70Go of data on the 1To drive.
Thanks in advance,
PS: sorry for mistakes, french here.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Hi there. You can clone the drive no problem. As long as you don’t have more than 500GB of data on the drive and you said you only used about 70GB so you’re fine. The cloning software will resize the partitions to make it fit on the 500GB drive. You can get a Samsung Evo 860 series for under $150 if that’s in your price rang because a 500Gb is about $80. Can get them on eBay even cheaper brand new.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jean Cochet さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 16
過去 30 日: 31
今までの合計 145
