メインコンテンツにスキップ
GE Digital Messaging System identified by the model number 29875GE1
10回答 すべてを表示
Can I retrieve messages somehow deleted when I disconnected system?
I temporarily disconnected the answering machine and when I reconnected it, my 57 saved messages were gone.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi @doctorslow ,
When you say “I temporarily disconnected the answering machine…..” do you mean that you disconnected the power supply from the machine?
If so then unfortunately the machine has been reset and the messages would have been erased.
Was the machine using the default answer greeting message provided or did you record a personal answer greeting message?
If it was a personal recorded message check that the machine has now defaulted back to the standard message.
If so this verifies that the machine has been reset.
The user manual mentions batteries although it doesn’t show where to install them or what they are for.
Is there provision in the back of the machine to install batteries by any chance?
If so this may be a way of saving your messages in the future in the event of a power failure etc, as it may provide backup power to hold the data. This is just a guess on my part if there is a battery compartment in the machine.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank-you very much!!
さんによる
コメントを追加
回答を追加する
Robert C. Zwicki さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 124
