Park lights won’t turn off
Park lights stay on after vehicle is turned off
@harv177 common issue on the H3 is a short in the trailer wiring touching the chassis and causing issues. Open the tailgate and carefully inspect the wiring harness. Pull the Trailer B+ fuse and see if that turns the lights off. If it does you know it is a short in that wiring. If it does not, check the light switch with a multimeter.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 664
