Hi @jason11 ,
A blinking power light is an indication that the laptop is in sleep mode.
Try either force stopping and shutting down the laptop by holding the Power button until it shuts down completely and then restart the laptop in the normal way
or
Try opening and closing the lid a few times and check if the laptop comes out of sleep mode by itself.
Hi @jason11 ,
Can only suggest to reset the BIOS to default in case there are any corrupted settings which may prevent the laptop from functioning correctly.
To do this open the laptop and remove the battery pack and the RTC battery, press and hold the Power button for 30 seconds and then release the button and then replace the RTC battery and the battery pack.
Hopefully by doing this you will have reset the BIOS to default settings
Here's a link to the service manual for the laptop, taken from this webpage.
Scroll to p.40 to view the necessary pre-requisite steps and then the procedure on how to do this.
After you have done this, reconnect the charger and check if the laptop starts to charge correctly.
If it still won’t charge then you have a motherboard problem
If it starts to charge allow it to charge fully before attempting to start the laptop.
If it starts OK allow it to boot all the way to the Windows desktop and allow the HDD activity to settle before checking things.
If you have Win 10 installed check if you have the latest chipset drivers and latest power management drivers installed. Click on the “see files” arrow to view details of driver version and release date.
9 件のコメント
Any update on this? I have the same problem
Humam Abusitta さんによる
same problem with a lenovo ideapad 320s, one month after warranty end!
gregory さんによる
i have the same problem with jason
Fernando Martinez さんによる
It charges very well when the laptop is off
Then when I plugin the charger while using the laptop, just not more than 3 minutes it starts blinking and stops charging
mayanjataban さんによる
my lenovo T450 is blinking the power button as soon as i plugin the charger and won't power on, it does all this when the power button is not pressed please help....
FORBES KAY さんによる
4件以上のコメントを表示
