Where can I find bottom screws?
All I am looking for is just one long screw that is suppose to go at the bottom of the unibody macbook pro 13" early 2011. Where can I buy just one screw? Thank you!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The Genius Bar will probably have some off a junked laptop from a customer. I would try your luck there. If not, they have them in the back.
このアンサーは役に立ちましたか?
If Nicks answer fails, here's the whole set: MacBook Pro 13" Unibody (Early 2011-Mid 2012) Screw Set
このアンサーは役に立ちましたか?
you can put some of the non permanent lock-tight on the screws before you install them
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 1,704
1件のコメント
Thanks guys Ill go give it a try!!!
Louis Lu さんによる
