How can I repair my tv?
Hi ! So Last night I was just watching tv with my family , when a loud pop just came out from the back of the tv , and a little flash too , and the screen just went all black. I quickly unplugged the power from tv , waited a little until the tv was “ discharged “ and I uncovered the back of the tv , and this is what I saw —>
Could this possibly get fixed ?
Every answer is helpful and mighty appreciated
この質問は役に立ちましたか?
5 件のコメント
YouTube is your best friend for this
Mine turtle music さんによる
Hi,
What are we supposed to be looking at?
Are you referring to the white silicone paste that is under some components?
This is there to hold them in place and that they do not break due to vibrations.
The R413 resistor has a black spot on it which could just be dirt but otherwise everything in the image appears OK.
What is the model number of the TV?
Is the power standby LED on or off when power is connected to the TV?
jayeff さんによる
just carefully desolder the resistor. Go to your local electronics shop. Get the same one (usually very cheap like $1). Repeat.
Edward C さんによる
The power standby is not coming
Hagan Cephas さんによる
@Hagan Cephas,
Have you checked the power outlet that the TV is connected to is working OK?
Disconnect the power from the TV, remove the back cover from the TV and check for any obvious damage on the TV power board e.g. blown fuse, burnt out components etc.
What have you checked?
jayeff さんによる
